Sponsored by:
Sponsored by: CARiD
2018 Daytona 392 CANBus issue?
Old Dec 9, 2024 | 02:29 PM
SHO Rod's Avatar
SHO Rod
Default 2018 Daytona 392 CANBus issue?
Over the past few weeks my 2018 Charger Daytona 392 has been having an issue that I think is likely related to the CAN bus, but I have not yet figured out the common denominator. At first it seemed rather sporadic, but I think has been getting worse now over the past week. Sometimes (now most of the time) when starting my car, several of the modules are disabled and set codes for communication lost. I don't have the list of codes handy but can pull them down again this evening. Consistently when this happens, the SRS is disabled, the Lane Keep Assist is disabled, the Blind Spot system is disabled, the HVAC is disabled, and the backup camera doesn't work (blue screen). Initially after driving about a block or two these would come back on, but now it seems to take several miles before they're resume working. And they all start working at the same time. Half of the bad units are on the Bus-H and the other half are on Bus-L, which causes me to think this might not be as simple as a bad solder joint or other loose connection somewhere. Once they start working, they so far have continued to work for the remainder of the drive. But if I stop, shut off the car, then immediately restart it they often start up in the disabled state. This further causes me to think it may not be a connection issue unless its a connection that triggers an interrupt or signal that gets latched and reset upon startup.
But I'm not sure if there's some common module that controls manages the High and Low CAN bus, maybe the Secure Gateway Module? I've tried resetting all the modules and tried leaving the battery disconnected for several minutes, but that hasn't yielded any noticeable change. I so have a Tazer installed using their bypass cable. When the modules are acting up, the Tazer also doesn't seem to be communicating with the car. I've tried leaving the Tazer disconnected and that doesn't make things better either.
Any suggestions before deciding I need to schedule an appointment with the dealership? I hate the thought of that, but I feel like I'm almost to that point. And of course I'd want to completely uninstall the Tazer before taking it in.
-Rod
Old Dec 10, 2024 | 12:10 AM
SHO Rod's Avatar
SHO Rod
Eeek, so scanning the car tonight with two different scan tools, both yielded 22 diagnostic trouble codes over 20 modules scanned. So strange, most of the codes do seem to appear to relate to a CAN bus issue in my mind.
System Code Description Status
BCM (Body Control Module - TIPMCGW/FCMCGW) U0264-00 Lost Communication With Camera Module - Rear (Active)
BCM (Body Control Module - TIPMCGW/FCMCGW) U1190-00 Lost Communication With Humidity Sensor (Active)
BCM (Body Control Module - TIPMCGW/FCMCGW) U0232-00 Lost Communication With Blind Spot Detection Module (Active)
BCM (Body Control Module - TIPMCGW/FCMCGW) U1215-00 Lost Communication With Forward Facing Camera (Active)
IPC (Instrument Panel Cluster) U0159-00 Lost Communication With Parking Assist Control Module (Active)
SRS (Supplemental Inflatable Restraint System - ORC (Occupant Restraint Controller)) B212D-13 Ignition Run Only Input-Circuit Open (Active)
TPMS (Tire Pressure Monitoring System) C1503-96 Tire Pressure Sensor 3-Component Internal Failure (Stored)
ACC (Adaptive Cruise Control) U1215-00 Lost Communication With Forward Facing Camera (Active)
ACC (Adaptive Cruise Control) C2227-00 ABS (Anti-lock Braking System) Disabled ECU (Stored)
ACC (Adaptive Cruise Control) U0415-00 Invalid Data Received From ABS (Anti-Lock Brake System) Control Module 'A' (Stored)
EPS (Electronic Power Steering) U1215-00 Lost Communication With Forward Facing Camera (Active)
EPS (Electronic Power Steering) U148D-00 Implausible Data Received From Forward Facing Camera (Stored)
SGW (Security Gateway) B22A9-49 ECU Internal Performance-Internal Electronic Failure (Active)
HVAC (Heating Ventilation Air-conditioning And Cooling)/AC (Air Conditioner) B10E8-14 Blower Motor Control-Circuit Short To Ground Or Open (Active)
Radio B280B-00 NTSC Video Input Active Radio U11FB-00 Lost Communication With Left Blind Spot Sensor Active Radio U120E-00 Lost Communication With Comfort Seat And Wheel Module (Active)
Radio U11FB-00 Lost Communication With Left Blind Spot Sensor (Active)
AMP (Amplifier) U11FB-00 Lost Communication With Left Blind Spot Sensor (Active)
DDM (Drivers Door Module) U0232-00 Lost Communication With Blind Spot Detection Module (Active)
PDM (Passengers Door Module) U0232-00 Lost Communication With Blind Spot Detection Module (Active)
PDM (Passengers Door Module) B1751-15 Courtesy Lamp Control-Circuit Short To Battery Or Open (Active)
ICS (Integrated Center Stack) B210E-17 Battery Voltage High-Circuit Voltage Above Threshold (Stored)
-Rod
