Sponsored by:
Sponsored by: CARiD
AUTO HEADLAMP/SIRRUS CONVERSION
Old Sep 29, 2006 | 12:16 AM
khurst's Avatar
khurst
Default AUTO HEADLAMP/SIRRUS CONVERSION
Thought everyone might like to know (if you don't already) you can convert to auto headlamps by simply buying and installing the auto headlamp switch from your local Dodge dealer (about $35) as long as you were originally equipped with the electronic convienence group II and dual climate control.
Has anyone installed the available SIRRUS sat. radio/install kit available from Dodge? My R/T was not originally equipped with SIRRUS but it does have the 6 cd w/ cassette and sound group II. I would like to install SIRRUS but don't want an FM modulator type system and want it to be an original style install. Does anyone know if it is a plug in type install (I.E. no FM modulator) and is it difficult to install?
KHurst
Corpus Christi, TX
Old Sep 29, 2006 | 12:53 AM
MangoInTX's Avatar
MangoInTX
Charger Moderator
Default RE: AUTO HEADLAMP/SIRRUS CONVERSION
Thanks for the heads up. Is the auto headlamp switch the same as trimming the switch ==> see this thread on trimming the stop on the stock switch.
You might want to also post up your audio question in the "Audio/Visual Electronics" Section.
