Sponsored by:
Sponsored by: CARiD
b&g flash programming
Old Nov 10, 2006 | 12:27 AM
topbanna3767's Avatar
topbanna3767
Default b&g flash programming
hi everyone just when i think my problems are solved along comes sema and messes things all up now it seems there are more programs coming out for the computer.gs motorsports told me that when i do get the sc i will have to reprogram the pcm back to stock .so that leaves me back to step 1 .the new mopar performance programs im told are better then stock but not a whole lot better.what i would need is a flash from b&g programmeres would be best ? has anyone delt with this problem yet.also has any either used or inquired about them already plan on calling them fri but was looking for some other indepdent sources.
Old Nov 10, 2006 | 12:57 AM
MangoInTX's Avatar
MangoInTX
Charger Moderator
Default RE: b&g flash programming
B&G has been around and has done some good work but on the flop side some have had problems w/their flashes. I believe B&G has a policy if they don't deliver what was agreed upon they will refund your money. As long as nothing blows your OK.
If you looking to leap out on performance it's going to take P/TCM programming. B&G is a good source.
A good option would be to go w/the Mopar performance PCM. That will give a person a "backup" PCM that can be sent to... let’s say B&G for enhancement and tinkering. Swap-em out as needed.
No doubt, over time the programs for our cars will mature.
Old Nov 10, 2006 | 01:57 AM
topbanna3767
hi mango so what do you recommend ? getting the pcm and teh tcm and have them reprogrammed? tehn keep the stock ones ? .let me ask this the board is obviously the pcm the 3 modules what are they ? and does b&g only flash the pcm and not the tcm ? how does that work do you think ?
Old Nov 10, 2006 | 12:53 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
I don't see a downside to the new Mopar PCM. Run it for a while and if you want send the <edit> old one out for flashing, B&G is the only choice I'm aware of. If you find a new direction to go and don't need that new Mopar PCM I would bet there would be easy to sell it.
I'm not sure if B&G will flash the TCM, but there's that "enhanced" flash you can get a few places <=Heat Performance is one.
Not sure about the three modules, are you wondering what modules the PCM has?
<edit>
from canhack.org...
Canbus - There are 3 separate CAN buses in these vehicles.
-[CAN-C] Engine / Critical systems CAN Bus ( Engine, Transmission, AntiLock breaks, ESP, etc.. )
-[CAN-B] Interior Comfort CAN Bus ( Climate Control, Car Audio system, Dash cluster, EVIC, etc.. )
-[diagnostic CAN-C] Diagnostic CAN Bus ( Has the capability of pulling service codes from the other two buses, but not directly connected to either )
Old Nov 10, 2006 | 02:16 PM
topbanna3767
great thats what i thought they where for .so on to my next question the new mopar tcm coming out and ive seen heat performance has one as well its up for sale on highhorseperformance.com any opinions on which one might be better? by the way anyone know where the hell the tcm is located ?
Old Nov 10, 2006 | 04:13 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
Their probably the same programs.
No idea where the TCM is, if I see it I'll let you know.
Old Nov 11, 2006 | 12:15 AM
topbanna3767
ok ive gotten half an update the pcm and tcm being done for mopar is by a sub of chrysler called flight systems ,has anybody heard of them ? any ways there going to be programming the units next week for shipping onthe 20th approx.the programming that b and g use is it totally custom or is a unit that just has a more aggresive program from another car.also how crazy is chrysler going to get with these units i thnk im propably going to buy it anyways then send teh stock unit in to b&g .but they have a few types to choose from ,not sure which i would get ,i havent spoken to them directlty yet but i plan to tommorow if there open on sat if not on mon .
Old Nov 11, 2006 | 12:18 AM
topbanna3767
also im puzzled as to the cost of the program ? im supplying the unit there not really giving you anything other then a program and charging a crap load of money 600 plus dollars.i mean am i missing something is not what there doing to the unit pretty much the same as we do with the superchip? except they keep the program and if it needs to be redone another 600 plus ,at least with the superchip you can do it yourself all day long.there has got to be a way to get the program of the pcm and plug in a new program .i wonder if dodge sells the pcm as well .because my thinking is if it has to go into the dealer and they plug something in the pcm will go back to stock and there by killing the 600 dollar program.for a trip to dealer stock pcm would be a good idea.but to spend 300 bucks on a new pcm from mopar performance just to have it wiped clean would be a shame as well .how many pcm am i gonna have looks like 3 stock mopar and b&g my credit card is screaming .
Old Nov 11, 2006 | 01:38 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
Not sure what B&G uses to flash the PCM, but it goes way beyond the superchips. Their similar in that they hook into the data link connector (DLC), and are capable of read/writing to the PCMs EPROM.
As you saw they offer various types of flash for our car including custom. Go to B&G if’n you want to:
MDS disabled
Idle RPM adjustment
Different fuel maps
Different timing maps
They also use software emulation to see what the tune will do prior to putting it in a vehicle.
Their price is due to supply/demand. They got something that is in limited supply, the knowledge to program your PCM more aggressively than over the counter programmers. PCM performance tuning outfits aren’t found on every corner like 7-11 quick shops.
Old Nov 11, 2006 | 03:40 PM
topbanna3767
well looking at it like that i guess when the market is cornered you can charge what you want.it does take knowledge to do it but im just still a little amazed
