Sponsored by:
Sponsored by: CARiD
Problems with R/T
Old Dec 15, 2006 | 06:25 PM
hemi2nv's Avatar
hemi2nv
Default Problems with R/T
Have a few ?'s. I put in a Jet Performance Mod this morning and the increase in power is insane, but now I can't get my auto up window feature to work. Could installing the Mod have deleted a code and is there something i can do to reverse this. The other question is there anyone out there that is having problems with there sound system going to all static no matter if it is a cd, sat radio, FM/AM radio. I got my r/t in August and this problem started the first night i had it. The dealer can't figure out what is going on. I have taken it in numerous times and they have replaced the radio head unit and that didn't work. They have a amp and wiring harness on order but it has been backordered until sometime in Feburary. Seven months with this problem I am does not make me happy at all [:@]. If any one may know what is going on and how to fix these problems let me know.
Brian
Old Dec 15, 2006 | 06:57 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
Default RE: Problems with R/T
Welcome to the forum hemi2nv.
Your auto window feature needs to be calibrated after battery disconnect. Here are the steps:
1. Press the switch to raise the window all the way to the top.
2. Hold the switch in position for 1 second.
3. Press the switch to lower the windows all the way down.
Sorry not sure about the static issue.
Old Dec 15, 2006 | 07:02 PM
hemi2nv's Avatar
hemi2nv
Thanks for the info
Old Dec 18, 2006 | 08:24 PM
BigBananna3796of4000's Avatar
Mango,
Do you have to disconnect the battery when installing the Jet2 chip?
Also do I ahve to put the 180 degree thermo in?
Old Dec 18, 2006 | 11:36 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
I would disconnect the battery before installing the JetChip. As you probably know, the lower T-Stat is recommended by Jet but I don't think you really need it. It’s not going to over heat.
I ran the JetChip stock for a while then put in a 190. I switched to a 180 after getting the SC Flashpaq.
Old Dec 19, 2006 | 12:27 PM
Do you like the SChips better than the Jet2?
Old Dec 19, 2006 | 12:31 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
Yes, but you have to weigh what you may do in the future against what you want today.
There's not much more I can do for HP w/o a custom tune. I'd like to see some available from SuperChips but there's nothing yet.
