Sponsored by:
Sponsored by: CARiD
DIY Tranny Dip Stick
Old Jan 3, 2007 | 01:50 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
Default DIY Tranny Dip Stick
Check this out...
https://dodgeforum.com/m_616957/tm.htm
Old Jan 3, 2007 | 03:19 PM
74scamp's Avatar
74scamp
Default RE: DIY Tranny Dip Stick
That's good info. Mine finally startedleaking, so I need to take it in anyway.
dave
Old Jan 3, 2007 | 03:33 PM
earthchain's Avatar
earthchain
Interesting. A dip stick can be made, but on the 5 speed it should be marked in millimeters. The oil temp needs to read from a star scan type tool and the level adjusted in accoradance with a chart in the service manual.
Old Jan 3, 2007 | 03:57 PM
baldyloxs's Avatar
baldyloxs
Yea when I called them ,hey told me that was the only way the tranny should be low is if it were leaking.That was the reason for no DIPSTICK.Now my buddie has a new ford superduty it is the same way no dipstick .
Old Jan 3, 2007 | 05:33 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
I also read the temp thing as well. There are other paramaters that "should" be looked at when checking the fluid level of the tranny. You'd think as long as you measure it consistantly (same temp, Imperial Inches or Metirc) that would do it.
