Sponsored by:
Sponsored by: CARiD
Mod's??
Old Mar 11, 2007 | 05:30 PM
bandit96's Avatar
bandit96
Default Mod's??
Ok so here is the plan... (this is for Charger Daytona) I have already ordered Superchips programmer, S&B Cold air intake, Motoblue Throttle Body Spacer. (all came together in a package) Now the question is i want to get the HHP TCM stage 2, will the superchip's work with this? Or is the mopar pcm better the superchips?? And im going to do the no esp mod also. So would all of this work or will i have problems
Old Mar 11, 2007 | 06:00 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
Default RE: Mod's??
Not sure about the TCM IIand SuperChips (SC)but if you ask High Horsepowerthey will know. All you can do with the SC is raise the shift limiter, I'm not sure if you would want to do that with the stage II TCM.
The Mopar performance PCM is more aggressive withit's settings from stock. I'm not sure but possibly you can use the SC with it.
The ESP switch is highy recommended.
Old Mar 11, 2007 | 11:31 PM
baldyloxs's Avatar
baldyloxs
Default RE: Mod's??
I agree with Mango not sure about the SC.I am thinking you have some different things you could do with the SC like codes,tire sizes n stuff like that.
Old Mar 11, 2007 | 11:39 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
Default RE: Mod's??
Absolutely, the SC is helpful in many ways.
Old Mar 11, 2007 | 11:42 PM
bandit96's Avatar
bandit96
Default RE: Mod's??
very true, there is so much stuff to chose from.. i guess i cant go wrong
Old Mar 11, 2007 | 11:47 PM
baldyloxs's Avatar
baldyloxs
Default RE: Mod's??
Dont get me wrong!!! I was thinking bout a new PCM, I am not sure if the darn tuner will do the other things with it.
