Sponsored by:
Sponsored by: CARiD
Thermostat
Old Mar 12, 2007 | 01:00 PM
BigBananna3796of4000's Avatar
Default Thermostat
thermostat[/align][/align][align=left][/align][align=left]I am wanting to change my thermostat what do I buy and how hard is it to install?[/align][align=left][/align][align=left]I have clue where it even is located?[/align]
Old Mar 12, 2007 | 01:45 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
Default RE: Thermostat
I'm running a NAPA 180 degree part # 191 THM
Here's a pic showing the location of the thermostat. There are two bolts, I believe you will need a 13mm socket or wrench.
[IMG]local://upfiles/33009/218F6E9AB5644EDCAE8726BFD3CC9032.jpg[/IMG]
Old Mar 12, 2007 | 03:28 PM
baldyloxs's Avatar
baldyloxs
and a ziplock baggie to catch xtra fluid to dump back in,adn about 10 min .
Old Mar 12, 2007 | 03:59 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
After you take the two bolts that hold the topthermostat housing and pull it loose you will see thermostat. Use a small screwdriver to pry it out, be sure not to damage the rubber seal on the outside lip of the thermostat. When it comes out so will some antifreeze. You'll need to move the rubber seal from the OEM T-stat to the new T-stat.
I took the sloppy route and let it dribble everywhere, once done I added a little distilled water to the overflow.
Marty is right - the zippy bagthing is the next best thing to the Charger, it's so simple& priceless. Just hold the zippy bag under the housing and let it catch anything that spills out and after your done pour it back into the overflow container.
Old Mar 13, 2007 | 05:39 PM
Ahhhhhhhhhhh good point I will use the zippy bag trick.
Old Mar 14, 2007 | 11:24 AM
One more question.
Can I use a lower temp thermo than 180 sinceit is so hot in TX or is it a waste of time?
Old Mar 14, 2007 | 01:15 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
You can try it. I ran a 195 then the 180. So at any time I can swap between the 203 or 195 or 180.
I don't think you want to go colder than 170, it would probably throw codes.
PepBoys has Stant T-stats. 170degree part #s:13947 - 170, 14127 - 170, 14177 - 170 They may not have them in stock but they can order them.
Old Mar 15, 2007 | 03:53 PM
baldyloxs's Avatar
baldyloxs
I hear of alot of fella on the LX forums throwing codes like mad with the 170Motorad thermo.I'd prob stay away from the 170 motorad try a NAPA or the other Mango was talking about
Old Mar 27, 2007 | 08:50 PM
I just called Napa and they are telling me part #191 is for a different vehicle?
DoI ask for a truck one or something?
Old Mar 27, 2007 | 09:41 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
191 THM is what I have in my car right now. It's a 63mm T-stat which is the correct size.
I'm typing this from my PDA sorry for the short reply.
