oil filter for a 440
Old Jan 28, 2009 | 11:53 PM
Rmvr53's Avatar
Rmvr53
Default oil filter for a 440
Just got a 77 D200 with a 440-1 under the hood. I was looking at oil filters and have a question. Book says its a PH43 (fram part number) bit I was comparing the "business end" of a couple of filters and have a question. Can a FL-1 (big Ford filter) be used instead of the smaller 43? The threads and seal appear to be the same and I always like a bit more filter area for my rides.
thanks
Bill
Old Feb 27, 2009 | 09:19 PM
60 Dart's Avatar
60 Dart
National Mopar is the answer
If the Threads are the same I couldn't see a problem with that
Old Mar 10, 2009 | 11:24 AM
77Utiline's Avatar
77Utiline
Both the "high performance" FL-1 and the PH8A will fit on Mopars. I run the 8A (or equivilant on my Mopars) because I prefer to run a 1qt filter as opposed to the 43 which is only 1/2qt. Which raises the total capacity (on small blocks anyway) to 6qts.
Old Mar 11, 2009 | 10:38 AM
60 Dart's Avatar
60 Dart
I also Run the 8A it works great after i put an oil filter adapter on her
