Parking Brake Adjustment Problems???
Old Sep 6, 2009 | 09:20 PM
60 Dart's Avatar
60 Dart
Exclamation Parking Brake Adjustment Problems???
Hi guys i noticed that my E-brake wasnt working so i opened up the rear brakes but no E-brake cable. I noticed that before the Drive shaft there was the E-brake it hooks up there and was wondering how to adjust that tighter??? Thanks in adv
Old Oct 3, 2009 | 10:36 PM
charon187's Avatar
charon187
do you mean that the e brake is a drive shaft brake? as in if you were to reverse brake shoes and wrapped them around the drive shaft? if so i think its called a clutch brake??? anyway thier should be a bolt on the top or bottom that has a spring over the bolt to keep it open. if i remember right you tighten the bolt to close the clearance between the friction material and the drive shaft.
Cheers!
