Alive '65
Old Apr 8, 2005 | 04:17 AM
ducktape's Avatar
ducktape
Default Alive '65
Hey all you peoples out there. I got myself a 1965 Dodge D-100 Pickup. Man this truck is great... it still has the original trim too! Yeah I dunno what I want to do but I know first would have to be getting the air filter on there that it doesn't have and maybe seeing if I can fit a 4 barrel carb on it instead of the 2 barrel it has already. Either way, I jus wanted to know what others have done with such a similar truck. I'd use it for 4x4 since I'm in Alaska but it's 2 wheel drive so I figured I'd make it a rice burner. Eh, questions, comments, things of those sorts is what I'm lookin to read. Take it easy peoples. - Andy
Old Apr 8, 2005 | 10:08 AM
TeeWJay426's Avatar
TeeWJay426
Default RE: Alive '65
That's a pretty rare animal you have there... most of the pickups of that vintage were worked hard until they couldn't work anymore, and then got sent off to be recycled into a half-dozen Toyodas..... I'd restore it to as close to original if it was me, but it's your truck so it's your call. A big block would be a nice transplant into that as well! How's the body on it? Got any pics? Being a '65, that's the old style 318... also known as the 'wide block'... so a lot of the standard small-block Mopar stuff won't interchange. Not sure what's available for them, as I've never had one and never had to chase parts for one as a result. Good luck with it... let us know what you do with it, and post some pics when you can.
Old Oct 22, 2005 | 01:12 AM
ducktape's Avatar
ducktape
Yeah.. my bad for not posting as much. Big list of things occurred.. None of which to mention again. Yet I finally had gotten some pics of my pickup and found a place to host 'em too. There she is in all her glory.. well before things occurred. I had the clutch go out on me and had it rebuilt. Then I got the clutch in but I broke a brake line that was going from a master cylinder to the clutch pump. When I finally got the brake line bent enough to thread into its rightful places I overlooked that one of the connections had been touching a conductor that all my wiring was hooked up to. When I started her up she was smoking and the wiring all got fried.. now I gotta go find me a couple other things now to get her back in shape. At least I don't gotta get her I/M'd ahaha. Well I hope to hear from you peoples on what you thinks of her. And yeah TeeWJay she does got a 318.. 3 in the tree.. and I still haven't found an airfilter assembly for her yet. All will work out in due time though. Take it easy - Andy
