'69 D300 exhaust manifold/ down tube
Old Aug 25, 2021 | 10:44 AM
gshort1344's Avatar
gshort1344
Default '69 D300 exhaust manifold/ down tube
Hello Dodgers !
This connection doesn't look right for obvious reasons. (see pics) huge gap..... the flange on the down tube appears to be larger than on the manifold.
questions:
1. Is this a common problem? (finding a downtube the correct size)
2. I'm interested in taking this apart to fix, but scared to hurt the manifold as it's pretty rusted.
3. Should I care?
Thank you for helping a rookie trying to learn.
Greg
Old Aug 26, 2021 | 05:48 PM
Moparite's Avatar
Moparite
Looks like someone over tightened it and bent it. If you remove the bolts slide the flange down the pipe where you can straighten it. Put it back with new hardware and a gasket.
