Dodge w250
Hej. I have problem with my dodge w250 1989 5,2 liter.
when I kick the pedal to gas, it Will not respond direct. I looks it run out of gas in a milli secund and then get it. Can it be vaccumleak? Fuelpressure? The old owner talk about tempsensor. But the temp sensor to the instrument work. It must be another tempsensor to the computerbox. Do you have any ideas?
The injectors are new.
Sorry my bad english, Im from sweden 😀
Your English is better than some people I know who were born and raised here.
Hur mycket bränsletryck har du? Hur många mil på bränslepumpen? En svag pump kommer att orsaka det.
(No, I don't speak Swedish. I do speak Google translate.
I havent measure the fuelpressure yet.
But i think mayby the fuelpressure is the badguy here. I have a extern fueltank and pump on the trunk. The fuelfilter is new.
Det kan vara problemet. Jag tror att ditt fabrikstryck är cirka 45 men många eftermarknadspumpar går 10-20. Se om du kan hitta en pump med högre tryck.
Aint that the truth! Cell phone speak is what we see here all the time! No punctuation or capital letter's at a beginning of a sentence. Then if you say anything about it they get flustered. I bet English teachers are going out of their mind's now a days. If it's not a fuel pressure issue it could be the TPS.
I have a new tps at home. Mayby I just try to change it.
