Dodge Dakota The tough, mid size pickup, the Dodge Dakota. The Dodge Dakota has everything the big boys do with a mid size truck price.
Front end noise help
Old Jul 23, 2007 | 11:24 AM
mtbmark's Avatar
mtbmark
Default Front end noise help
94, 4x4, 3.9, 103k miles. Developed rotational squeek up front. Sounds like a u-joint, but replaced ALL of them, and it continues. Also, still had original front brakes and replaced all the works. Squeek goes away if the front drive shaft is out.(Lube levels fine) But now with the front driveshaftrebuilt and balanced at a driveline shop, I'm thinking the hub bearing(s) may be the source. Advise, Thanks
