Dodge Dakota The tough, mid size pickup, the Dodge Dakota. The Dodge Dakota has everything the big boys do with a mid size truck price.
Intermittent braking problem
Old Aug 16, 2007 | 06:14 PM
94DakotaNightmare's Avatar
94DakotaNightmare
Default Intermittent braking problem
I have a 94 dakota 5.2 litre 4x4. Ocaisionally the brake pedal will go to the floor. After releasing it ad hitting the brakes again it will be fine. Soemtimes I will have to pump them once or twice first. Seems to only happen in cooler temperatures.
Any ideas?
Old Aug 16, 2007 | 06:57 PM
owns's Avatar
owns
Default RE: Intermittent braking problem
Bad master cylinder would be my bet.
You can get a rebuild kit, or a whole new one for around $150.
Old Aug 16, 2007 | 08:09 PM
94DakotaNightmare
Guess I should have included that the master cylinder, front calipers and rotors are all new.
Old Aug 16, 2007 | 09:28 PM
injmopar's Avatar
injmopar
Take the master back it is a dud
Old Aug 16, 2007 | 10:10 PM
owns's Avatar
owns
Have you bled the brake lines for air?
Old Aug 16, 2007 | 10:25 PM
94DakotaNightmare
Yes, in fact the master cylinder was bench bled and we went through an entire large bottle of brake fluid. There is no air in the lines. It's an intermittent problem, tat's what has me stumped. I'v never known brakes to only be goofy sometimes, either they work or they don't. But mine ...eh they work most of the time but wen it's cooler they don't always.
Old Aug 17, 2007 | 10:12 AM
owns's Avatar
owns
Hmmmm...
Brake booster?
Old Aug 18, 2007 | 03:12 PM
rezonator's Avatar
rezonator
check adjustment of rear drums, if they are not adjusted there is a big gap between the shoe and drum
possibly bad proportioning valve
Old Sep 1, 2007 | 08:40 PM
Nicegy525's Avatar
Nicegy525
brake booster, rear wheel brake cylinders could be leaking. I had that problem with my '90 dak and the rear cylinders had come entirely apart and were puking fluid all over my wheels
