Dodge Dakota The tough, mid size pickup, the Dodge Dakota. The Dodge Dakota has everything the big boys do with a mid size truck price.
no power/backfire/shake!!!
Old Sep 15, 2007 | 03:52 PM
nghtwlf04's Avatar
nghtwlf04
Default no power/backfire/shake!!!
started having problems at 82k miles with 1999 dodge dak 4wd 3.9 v6. engine has rough idle, very little power and once in a while will backfire through throttle body. also while applying steady pressure to gas pedal truck will shake, like it's starvin for gas. if i let off gas it smoothes out or if i mash the gas and go into pass gear it will smooth out. mainly happens at 45mph at 1500 rpm's. cat was replaced about a year ago per the dodge extended warranty and tps also. i have done a full tune up except the coil with all mopar parts. any help is greatly appreciated.
Old Sep 16, 2007 | 07:12 PM
Nicegy525's Avatar
Nicegy525
Default RE: no power/backfire/shake!!!
its probably the coil, did you replace the fuel filter?
Old Sep 16, 2007 | 10:23 PM
nghtwlf04's Avatar
nghtwlf04
no i havent replaced coil cause i thought it would have trown a light if it were bad??? im workin on gettin the fuel pressure tested soon. that should tell me if its a problem in the fuel system, right??
Old Sep 17, 2007 | 12:00 PM
Nicegy525's Avatar
Nicegy525
a coil wouldnt necessarily throw a code. Mine didnt. the fuel filter is so cheap its worth replacing anyways. If the factory one is still on there at 82K miles it should be replaced anyways.
Old Sep 17, 2007 | 01:37 PM
nghtwlf04's Avatar
nghtwlf04
i thought the fuel filter and the pump were one unit? in other words you have to replace the pump and filter all at one time? how do you test a coil?
Old Sep 18, 2007 | 02:04 AM
Nicegy525's Avatar
Nicegy525
fuel filter should be a metal cylinder along the drivers frame rail. its like $15 at Napa. I dont know how to test an ignition coil. I assume it has one coil for all 6 cylinders. In which case that too is a cheap part. for an hours diagnose time, the dealer can usually pinpoint the problem. Then you can buy the parts and do it yourself for way cheaper.
