Dodge Dakota The tough, mid size pickup, the Dodge Dakota. The Dodge Dakota has everything the big boys do with a mid size truck price.
Thermostat
Old Dec 12, 2007 | 07:23 AM
steve05ram360's Avatar
steve05ram360
Default RE: Thermostat
hope it's not to late here... what year & motor do you have in your truck? the 3.9/5.2/5.9 motors like the 180 deg t-stat and autolite 3923's (non-platnum). if the one you buy doesnt have the air bleed hole in it, drill a small hole in the diaphram before putting it in. this will help with getting all of the air out when filling the cooling system back up.
Old Dec 12, 2007 | 04:46 PM
geoffb123's Avatar
geoffb123
98 5.2L V8..... and its not to late yet. I was going to do it last sunday but I never had time
Old Dec 12, 2007 | 07:52 PM
w9awx's Avatar
w9awx
Maybe I missed something, but, if is he wants the engine to warm up faster, and he already has a 180 degree thermostat, why would he want to stick with the colder 180 degree thermostat in the winter time?
Old Dec 13, 2007 | 12:47 AM
geoffb123's Avatar
geoffb123
Im not so sure as to what the thermostat in the truck is right now. But I know its stock. I just want heat quicker
Old Dec 13, 2007 | 10:03 AM
w9awx's Avatar
w9awx
Well, if it is the stock thermostat, it will bea 190-195 degree one. If it is the original one,the springis probably very very weak. This would cause it to open very early. Flush the cooling system, backflush the heater core, change the thermostat with a new 190-195 degree one, top off the fluids and you will have the best heat you will be able to get.
Old Dec 19, 2007 | 08:11 PM
geoffb123's Avatar
geoffb123
Just changed it, also put it some new double platinum bosch plugs. Im ready to roll
Old Jan 20, 2008 | 12:00 AM
mini's Avatar
mini
they've very simple to change, will definitely get some coolant on your engine but its not big deal.
Old Jan 20, 2008 | 12:58 AM
geoffb123's Avatar
geoffb123
After I changed it out I could definetly tell a big difference in the heat up process. Blows hotter air, and it warms up alot quicker. Thanks guys
