Dodge Dakota The tough, mid size pickup, the Dodge Dakota. The Dodge Dakota has everything the big boys do with a mid size truck price.
PCM is shot, now what?
Old Mar 1, 2008 | 10:51 PM
CSXfan's Avatar
CSXfan
Default PCM is shot, now what?
Hi all, I'm sure some of this has been discussed before, but I couldn't find much through the search function.
I found out yesterday that my PCM istoast and I need a new one if I want my truck to run decent in cold weather. I figure I have 2 options.I can go to the junk yard and get a used PCM. I need to get one with the ID#4886 661, or 4798 342. Cananyone tell me if these PCMs were used in any otherChrysler vehicles, or am I limited tofirst gen. Dakotas?
My second option is to get a performance PCM. I've been doing some research and it looks like I can get eitherJET stage 1 or 2, or I can get the Mopar Performance PCM. Does anyonehave experience withJET or Mopar Performance PCMs? How do you like it? Are there any drawbacks?I've heard that the JET PCMs have a habit of failing or randomly starting on fire, is this true?
My truckis a 1994SLT 3.9 4x4 withhigh-flow exhaust, K&Nair intake, modified V8 TB, and 180* Tstat. Any info you can give me is appreciated. Thanks!
Old Mar 2, 2008 | 01:00 AM
injmopar's Avatar
injmopar
Default RE: PCM is shot, now what?
Are you saying that your truck only runs bad in cold weather. Who tested the ecu.
Old Mar 2, 2008 | 09:45 PM
CSXfan's Avatar
CSXfan
Yes it only runs bad in cold weather (under 40*F). I have about a dozen other posts describing the problem thorougly but in a nutshell the truck only runs bad 8 minutes after starting to about 13 minutes after starting. Then it runs great. The local Crysler dealer (who I trust very much) tested my computer and told me it was bad.
I'm leaning toward the performance PCMbecause I don't really trust anything from thejunk yard. So whichone do yourecommend? JET or Mopar?
Old Mar 3, 2008 | 02:32 PM
TheePlaymaker's Avatar
TheePlaymaker
i have heard lots of good things about the mopar performance pcm and if i ever decided to get something i would definitaly go that route.
Old Mar 3, 2008 | 11:13 PM
herkguy's Avatar
herkguy
I ran a mopar pcm in my 94 dak 5spd and liked it alot, without other mods you will limit gains though
Old Mar 6, 2008 | 08:33 AM
CSXfan's Avatar
CSXfan
I talked to the guys at the dealer and they informed me that mopar doesn't make a performance PCM for a '94 3.9. They quoted me $525 for a stock PCM. I then emailed JET and they said that their chips aren't replacement PCMs they just work with the stock PCM. So now what? Do I really have to go to a junkyard and hope I find something that works? Any other ideas? Thanks
Old Mar 7, 2008 | 11:32 AM
herkguy's Avatar
herkguy
you cann save 200.00 through this site on new mopar.
https://www.dodgeparts.com/oe_parts_...34a0cd4ed4cc92
I know its still not cheap but better than 525.......
Old Mar 7, 2008 | 09:25 PM
CSXfan's Avatar
CSXfan
Thanks herkguy,
I'm going to try the junk yard this weekend. I'd rather spend $10 than $300 but if worse comes to worst I'll start looking for a brand new PCM
Old Mar 8, 2008 | 09:55 PM
injmopar's Avatar
injmopar
While your at the junk yard grab both the water and air temp senders. The ECU should not only give you a problem at -40.
