Dodge Dakota The tough, mid size pickup, the Dodge Dakota. The Dodge Dakota has everything the big boys do with a mid size truck price.
Want to Lift truck
Old Apr 24, 2008 | 08:03 PM
wworks's Avatar
wworks
Default Want to Lift truck
Hi.
I have a 2000 Dakota club clab with the V6 and manual 5 speed.
I want to put a body lift on it and get bigger tires. I saw another dakota today that apparently had a 3 inch body lift and 33
inch tires. has anyone else done this? also what else would i have to modify or watch for when lifting, such as the shifter or any wires? thanks a lot.
Evan
Old Apr 25, 2008 | 05:27 PM
Truck Dude's Avatar
Truck Dude
Default RE: Want to Lift truck
check this thread out that i started, it might help a little.
https://dodgeforum.com/m_1285133/tm.htm
Old May 9, 2008 | 07:56 PM
strangemachine's Avatar
strangemachine
anybody have like illustrations of the actual components and a step by step guide? maybe stuff out of a hayes manual? thanks guys
Old May 12, 2008 | 01:40 PM
demarco0129's Avatar
demarco0129
I have a 99 5 sp v6 with a 3 inch suspension lift and 2 inches on tosion bars with 31's. I really suggest doing some more research before lifting and adding bigger tires. My v6 came this way used, but I can tell it is very sluggish and the stick is sort of out of whack from being jacked up so high, whoever did it probably didnt do it right. I love how it looks, but these v6s just arent strong enough for a lifted truck with 31's. Just my .02
Old Jun 25, 2008 | 09:49 PM
murdoc chongo's Avatar
murdoc chongo
I put on a 3 in body lift on my v6 5 spd manual. It is pretty simple really, things you need to watch the brake lines (which run along the frame) and the fuel filler neck (which they recommend you remove, i recommend u dont). u dont need to worry about the shifter, it will only be a little shorter but its not that big of a difference and i hardly notice it anymore. i have 31s and i wouldnt go any bigger cuz this v6 is a dog and it pushes hard. if u get aftermarket rims that are like 15x8 and slap some 31 mud terrains they look real sharp without having to be huge heavy 33s. hope this helps
Old Jul 1, 2008 | 01:27 PM
clanspanker's Avatar
clanspanker
I put a 3" suspension lift on my dakota and I am very pleased with the results. Make sure you get it professionally installed though. Suspension lifts are rather complex.
