Dodge Dakota The tough, mid size pickup, the Dodge Dakota. The Dodge Dakota has everything the big boys do with a mid size truck price.
95 Dakota Flasher Unit
Old Jan 31, 2004 | 11:55 AM
glennh's Avatar
glennh
Default 95 Dakota Flasher Unit
The flashers on my Dakota are blinking real fast. The hazards work fine and all the bulbs are OK, so I assume it is the flasher unit. Can anyone tell me where this is? </P>
Thanks</P>
Glenn</P><edited><editID>glennh</editID><editDate>38017.3721296296</editDate></edited>
Old Feb 1, 2004 | 06:35 PM
Dan K's Avatar
Dan K
Glenn,</P>
You are correct in assuming that it is the flasher unit. There are two seperate flashers in the dakota - one for the four ways and one for the two ways. Both of these are round and are located with the fuses under the dash on the driver's side. I recommend getting an electronic flasher rather than the mechanical type. This will give you a consistant flash rate, even when you are flashing trailer lights.</P>
</P>
-Dan</P>
Old Feb 2, 2004 | 11:38 AM
glennh's Avatar
glennh
</P>
Dan,</P>
Thanks. I'll check out the electronic ones as yopu suggest.</P>
Glenn</P>
</P>
