Dodge Dakota The tough, mid size pickup, the Dodge Dakota. The Dodge Dakota has everything the big boys do with a mid size truck price.
Doing some upgrading, comments plz.
Old Feb 4, 2005 | 12:27 AM
WrestleRideLive's Avatar
WrestleRideLive
Default Doing some upgrading, comments plz.
I recently purchased a '97 Dakota Sport
-5.9L/360ci/v8
-stock intake
-split flowmasters(single muffler system)
I am looking to throw a intake on(looking at k&n FIPK #57-1509-1)along with new True dual exhaust(headers, mufflers, pipes and anything else needed. Looking at Flow's Series 40 Delta or Original Flow)
Recommendations on Headers and anything else i might needed.
Old Feb 4, 2005 | 12:30 AM
Spyder's Avatar
Spyder
Default RE: Doing some upgrading, comments plz.
m1 intake manifold and 52mm throttle body and a pcm flash after all of the other upgrades.
Old Feb 4, 2005 | 01:04 AM
WrestleRideLive
Awesome, any websites that you recommend?
Old Feb 5, 2005 | 02:48 PM
BlueDak's Avatar
BlueDak
Couple of thoughts for you. I used to have the K&N FIPK kit, I was not impressed with it. COnstantly had problems due to what I believe is a design flaw. When it mounts on the TB, it is offset to the original mounting, and I think this causes some stresses in areas where they create other issues. Plus I had a TB spacer, this added to the problem, and eventually K&N voided my warrenty. Each time the hat would break I would call for a new one, they found out about the TB spacer and said this was the cause and voided the warrenty. I am now using an AFE CAI, I like it 10X better, better design, better allowance for engine flex, and I think it flows better as its design blocks more engine heat and seals better at the hood.
You may not be able to run true duals. If your state requires emissions, contact your emissions authority to find out. Some states will not permit true duals unless they came from the factory on the vehicle.
I have been hearing good things about Fastman and Edlebrock TB upgrades.
Old Feb 6, 2005 | 04:00 AM
WrestleRideLive
Sounds good, I will keep that in mind, Im not quite ready to buy i still have a couple weeks before doing so. Any ideas on a intake manifold and throttle body?
Old Mar 5, 2005 | 01:38 PM
Rick980's Avatar
Rick980
you can always run true duals, you will have to put a cat on both sides, that is all
Old Mar 16, 2005 | 11:01 PM
bagged318's Avatar
bagged318
check out this site: fastman.com
Old Mar 17, 2005 | 06:55 PM
95dak318's Avatar
95dak318
Yeah everyone says that the fastmans throttle bodies rock.
