Dodge Dakota The tough, mid size pickup, the Dodge Dakota. The Dodge Dakota has everything the big boys do with a mid size truck price.
p0551
Old Jun 20, 2005 | 09:18 PM
rem1019's Avatar
rem1019
Default p0551
Hi all new member here. Just bought 02 Dak quad cab 3.9..Cute lil truck..
problem is the same member coonsie posted about on 10/11/04 but no one replied.I ve got a mil on and the code is p0551 ps pressure switch which this truck does not have. Can someone help??? thank you....John
Old Jun 23, 2005 | 12:03 AM
coonsie's Avatar
coonsie
Default RE: p0551
John... Coonsie here... I received the following in an email from someone else that had seen what I posted here in this forum:
>I had the same issue. The dealer reprogrammed your ecu to a map that has
> the pressure switch on it. There is no way of goin back to the old programm
> but the dealer is obligated to install the pressure switch and the wiring
> harness to rectify the problem.
I have not done anything about mine yet, but I have to do something soon, as my truck is due for NYS inspection, and I believe they might not pass it with the check engine light on. I suppose I should go back to the dealer where I purchased the truck used, but they are over an hour away, and not the most friendly group to deal with to date....but I gotta do something...
Phil Coons
