Dodge Dakota The tough, mid size pickup, the Dodge Dakota. The Dodge Dakota has everything the big boys do with a mid size truck price.
1989 dodge Dakota 3.9L starting problems
Old Oct 15, 2013 | 06:33 PM
paulgrr's Avatar
paulgrr
Default 1989 dodge Dakota 3.9L starting problems
I am having some issues starting my 89 Dakota. I am getting fire to the positive side of the coil when I turn the key on. I'm not getting any fuel out of the injectors.When I do get fire, it's for about 3 seconds then it goes away. Any suggestions? I have been reading about bad splices or a bad ASD relay. Thanks, Paul
Old Oct 16, 2013 | 04:09 AM
elwoodmurrey's Avatar
elwoodmurrey
check the fuel pressure on it, it sounds like its not getting enough fuel to stay running,if its firing off the plug wires that's not ground wire or a coil bad on it,you may have a fuel pump or relay going bad on it,when it does this check it for fire at the plugs when it won't fire off,good luck
