Dodge Dakota The tough, mid size pickup, the Dodge Dakota. The Dodge Dakota has everything the big boys do with a mid size truck price.
dodge dakota 3 inch body lift troubles help?
Old Nov 4, 2013 | 06:11 PM
tkdbmy1's Avatar
tkdbmy1
Default dodge dakota 3 inch body lift troubles help?
i put a 3 inch body lift in my truck the bed was easy putting the lift in the cab I got it up and the steering extension for my lift wouldn't fit with my steering shaft. I want to have the lift in my cab also its a rack and pinion not a gear box can you help or give me ideas of what to do?
Old Nov 4, 2013 | 06:56 PM
jeepfreek's Avatar
jeepfreek
Can ya weld? I did a few body lifts on Jeeps over the years and it was common that the steering shaft wasn't quite long enough. It might sound scary but it really is a simple and common thing to cut the shaft and place an extension in it. I've also used an extension from Ididit that I don't see that they sell anymore but you might find from another aftermarket column company that was just bolted to the end of the original column and then the collapsible piece was just bolted to it. If you do decide to weld it take your time and inspect your work often for sings of cracking and fatigue but there's a lot less stress in a rack and pinion steering system than a traditional gearbox setup.
