Dodge Dakota The tough, mid size pickup, the Dodge Dakota. The Dodge Dakota has everything the big boys do with a mid size truck price.
Cb radio antenna help
Old Jan 27, 2014 | 09:29 PM
kickerman's Avatar
kickerman
Default Cb radio antenna help
Where can I put an antenna on my dodge dakota? That won't be in way or rust I was thinking between cab and bed? Also can I use a fire stick 4 ft antenna on a cobra cb radio?
Old Jan 27, 2014 | 10:01 PM
t.storey's Avatar
t.storey
you could get a hood mount, put it in the bed, or get a magnetic one for the roof. i wouldnt put it beetween the cab and bed. that will just hold dirt and stuff right there. if you live in the north where they salt the roads that could definatly rust. and that antenna should work. ive never heard of not being able to use a certain type of antenna with a cb. i have a president cb and a 4ft firestick
Old Jan 28, 2014 | 11:32 AM
kickerman's Avatar
kickerman
Ok where can I get that mount? And also you might know I narrowed it down to three radios idk which one is best the first one is a uniden pro 520xl another one is the midland 1001LWX with weather channel the last one I picked is the midland cb1 mini which one do you thinks best?
Old Jan 28, 2014 | 03:37 PM
t.storey's Avatar
t.storey
idk how many tools you have but mounts are really easy to make. ive made all of my own. this is the latest and the one that ill probably put on my dakota. just two holes for bolts to mount it and a bigger hole in the top for the antenna
also not gonna BS you. im no pro when it comes to cb's so i have no idea which one is the best, maybe someone else will chime in
Old Jan 28, 2014 | 04:45 PM
Daves69's Avatar
Daves69
I would think they all are good as long as you have it matched to your antenna. I like the weather band feature on my boat stereo.
It's been a long time since I used a Charlie Baker though. Do they have internal SWR bridges in them now?
Old Jan 28, 2014 | 11:13 PM
kickerman's Avatar
kickerman
Well idk if I have stuff to make one ? Idk what to use or how to do so... And ok the problem I read with the medland with wather scan is that the mic isn't very well. Also when I get it what fuse do I wore radio to?
Old Jan 29, 2014 | 09:15 PM
atthewmartin114's Avatar
atthewmartin114
go with the uni its the better quality of them. also there are meny meny different places to attach your ant. just remember any contact with the body you loose you ground out the signel and loose everything. the higher mounted the better but get a brake away spring so you dont snap off the ant. also theres probably someone in your area that can tune your swr to your firestick. well they do it have them adjust your swing and peak so you can up your output. you want about 30-45watts out put and about 25 to 30 watts input
