Low idle, throttle hesitation
I wasnt sure where to post so my apologies.
So, i have a '01 dodge dakota 3.9 magnum 2WD. Ive changed : pcv, iac, tps, map sensor, all the o2 sensors, cleaned throttle body. no vacuum leaks.
the truck starts normal (cold) will idle at 700/800 normally. when i drive and make it to a stop itll idle normal for a moment then work its way down to about 500 rpm (sometimes lower) and shake a bit. once the gas is pressed it hesitates a second then drives normally until i stop again. its never totally died out but im afraid it will soon. any information is appreciated, and thanks in advance.
