Dodge Dakota The tough, mid size pickup, the Dodge Dakota. The Dodge Dakota has everything the big boys do with a mid size truck price.
hard code p0442 med evap leak, where is my evap canister?
Old Aug 5, 2006 | 04:22 PM
chowyouare's Avatar
chowyouare
Default hard code p0442 med evap leak, where is my evap canister?
Was wondering where the evap canister is located. I have been getting this same hard code for over a year and getting kind of tired of seeing the check engine light. Also what symptoms will be relieved with the replacement of this part? My truck runs bad but all basic maintance has been complete.
Old Aug 16, 2006 | 07:41 PM
OldDodgeDriver's Avatar
OldDodgeDriver
Default RE: hard code p0442 med evap leak, where is my evap canister?
The cannister should be just in front of your gas tank. I suggest starting with the gas cap first. That's where I've heard the most failures.
from ODBcodes.com:
What does that mean?This indicates a fuel vapor leak in the EVAP control system. It means a very small leak has been detected. In fact, the leak can be from a hole as small as 0.04" in diameter. The (EVAP) emission control system prevents the escape of fuel vapors from a vehicle's fuel system. Fuel vapors are routed by hoses to a charcoal canister for storage. Later, when the engine is running a purge control valve opens allowing intake vacuum to siphon the fuel vapors into the engine.
Symptoms: You likely won't notice any drivability problems.
What causes code P0442? most likely means one or more of the following has happened:
A loose or improperly affixed gas cap
A non-conforming gas cap (i.e. not factory/original brand)
A small leak/hole in a fuel vapor hose/tube
Other small leak in EVAP system
Faulty vent o-ring seal
Possible SolutionsWith a P0442, the most common repair is to:
Remove and reinstall the gas cap, clear the codes, and drive for a day and see if the codes come back.
Otherwise, replace the gas cap, or
Inspect the EVAP system for cuts/holes in tubes/hoses
