Dodge Dakota The tough, mid size pickup, the Dodge Dakota. The Dodge Dakota has everything the big boys do with a mid size truck price.
bed liner??
Old Sep 18, 2006 | 02:19 PM
pilka214's Avatar
pilka214
Default bed liner??
ok so i'm looking into gettin a rhino spray in liner in the bed of my 03' dakota, but i'd like a lil input from you guys. so wut would you say are the best bed liners. thanx
Old Sep 18, 2006 | 09:12 PM
asmodeus289's Avatar
asmodeus289
Default RE: bed liner??
I got a Line-X a couple of months ago. I don't know if it's the best, but I'm sure it's up there.
Old Sep 18, 2006 | 11:14 PM
thakota's Avatar
thakota
i second the line-x. ive had rhino linings on a previous truck and ive seen line-x on some others. although the rhino performed as advertised the line-x looked much nicer. the rhino liner is low-pressure something something and its finish looks chunky. if appearance is not a concern either are good. the rhino is softer and more rubbery and the line-x is very hard. good luck.
Old Sep 19, 2006 | 07:24 PM
jonnymagnum's Avatar
jonnymagnum
I had an old jeep tj and the whole thing was painted with rhino liner inside and out. I loved that thing. and no matter what I hit with it I couldnt chip the paint or scratch it. if only it didn't look so chunky I would paint my dakota with it.
________
Kitchen Measures
Old Oct 6, 2006 | 08:47 PM
dak0ta_g33k's Avatar
dak0ta_g33k
i was going to get a spray liner but because i also wanted a camper shell over the bed i settled for a bedrug. it cost just the same as a speedliner install ($390 back in 2004). really pimps out the bed if you keep it covered. soft enough to sit on yet quite durable and easily cleaned.
Old Oct 6, 2006 | 09:44 PM
Rakaric's Avatar
Rakaric
could always save money and get a brush-on liner and do it urself.
AutoZone sells Herculiner for about 90 bucks.
Old Oct 21, 2006 | 02:44 PM
imnothot02's Avatar
imnothot02
ORIGINAL: Rakaric
this is what i did works great however if you are gna beat the hell out of your bed the line x is superior...normal use do it yourself is more than adequate
Old Oct 24, 2006 | 06:55 PM
Cozmo's Avatar
Cozmo
ORIGINAL: dak0ta_g33k
That looks sharp.
I think I need a regular bed liner though. Every truck shop that I've called in my area sells rhino.
Old Oct 24, 2006 | 08:37 PM
Twiztid's Avatar
Twiztid
2 questions.
How well does Herculiner with stand heat?
Can you coat an axle in herculiner?
Old Nov 1, 2006 | 03:05 AM
phatjohn's Avatar
phatjohn
I got a Line-X liner in '03 right after I got my truck. That liner has withstood mid-west weather and less the dirt, looks as good as the day I got it. After I first got it, I thought over the long haul, oxidation would discolor it (it's basic black) but that has proved to be a non-issue.
For my money, I would get a Line-X again in a heartbeat.
phatjohn
