Dodge Dakota The tough, mid size pickup, the Dodge Dakota. The Dodge Dakota has everything the big boys do with a mid size truck price.
Rack and Pinion
Old Oct 11, 2006 | 01:58 PM
hector5016's Avatar
hector5016
Default Rack and Pinion
My rack and pinion is leaking fluid on the drivers side (01 Dodge Dakota v-6 Quad Cab) . I priced them at Oreilley's and Autozone and they were about $180. Wanted to know if I should look for a rebuilt (haven't priced rebuilts)? Also is this a big job? I am pretty mechanically inclined and think I can do it if I have the right tools. I would like to know if a wheel alignment will be needed after this is replaced? If anyone has changed one of these let me know.
TIA,
Hector.
Old Oct 11, 2006 | 05:29 PM
RP Racing940's Avatar
RP Racing940
Default RE: Rack and Pinion
$180 is cheap (btw AUtozones are usually rebuilt ones anyways). Its not hard to replace them, just messy. And yes an alignment usually is a good idea since you'll be disconnecting the tie rods. Personally I string the tires for toe when I do steering work.
