Dodge Dakota The tough, mid size pickup, the Dodge Dakota. The Dodge Dakota has everything the big boys do with a mid size truck price.
4.7 Misfire
Old Nov 13, 2006 | 12:00 AM
Hilbili's Avatar
Hilbili
Default 4.7 Misfire
I have an 00 4.7 Dakota Quad cab 4X4 and have developed an occasional misfire. The engine light is on sometimes/ off sometimes. It gives me codes P0205 & P0207. The first engine light I had was a minor evap leak? Secured the gas cap and cleared and it went away. Now I notice the misfire at low rpm. If you put your foot to it, it runs like a raped ape. Just changed the spark plugs prior to all this starting, put in OEM plugs but didnt change the coil wires. Anyone know of a inexpensive place to buy a set of these coil wires? Also ran 2 tanks of Techron additive through the injectors. Any hints?
Old Nov 19, 2006 | 02:10 PM
Dakota Chris's Avatar
Dakota Chris
Default RE: 4.7 Misfire
Hi Hilbili,
see the attached link. I think you might have a problem with your fuel injectors. Maybe the Techron was a little bit to much or it losened debrie from you injectors or fuel lines that are now clogging up the injectors. It doesn't seem to be the spark plugs or cables.
http://www.ptcruizer.com/computer-codes.html
Hopefully that helps you.
Dakota Chris
