Dodge Dakota The tough, mid size pickup, the Dodge Dakota. The Dodge Dakota has everything the big boys do with a mid size truck price.
HELP-water under the carpet
Old Dec 3, 2006 | 01:02 AM
seekingland's Avatar
seekingland
Default HELP-water under the carpet
I was clening my 02 4.7L dakota club and notced that it was wet on the passenger side.
So I took the kickpanal out and lifted the carpet up and water started to poor out
of the yellow foam attached to the carpet.
Does anybody Know whats going on here and have info. on how to fix it?
Any help will be much apreciated
Old Dec 3, 2006 | 02:26 PM
jonnymagnum's Avatar
jonnymagnum
Default RE: HELP-water under the carpet
does it smell like coolant? if it does then it's your heatercore. if not then theres a leak somewhere.
________
Hot box vape
Old Dec 4, 2006 | 11:34 PM
Dakota Chris's Avatar
Dakota Chris
Hi seekingland,
I just had a similar problem on my 2005 QC and I saw where the water was coming in. It seems the water gets caught between the two rubber seals around the door (outer one along the top of roof to front of window) and inner around the door cutout. When it can’t find a way to run down between the two seals it will push behind the door cutout seal and run behind the two plastic panels that cover the footwell area (up to underside of dash) and from underside of dash to upper side of dash. There is a gap in between them (at underside of dash height) and you can check there by squeezing a tissue in there. It should be wet after a rain. I have monitored my leak and it has not happened again in two weeks despite heavy rain. It seems that it only happens when the door seals get jammed and there is not enough flow to the bottom. Hope that helps.
Dakota Chris
Old Dec 5, 2006 | 03:40 PM
Chris's Avatar
Chris
Both of these are viable solutions. Let's just hope it is the door seal, because the heater core replacement is not only a PITA, you will have to dish out some $$$ for a new one.
Old Dec 5, 2006 | 11:19 PM
seekingland
thanks for all your help guys.
found out it was the problem Dakota Chris explained.
