Dodge Dakota The tough, mid size pickup, the Dodge Dakota. The Dodge Dakota has everything the big boys do with a mid size truck price.
Door will not open
Old Aug 18, 2004 | 05:22 PM
speedreaderz's Avatar
speedreaderz
Default Door will not open
I have a 1996 dodge dakota and have a problem with the passenger door not opening.
My coworker and i got the door open by disassembling the door panel and he was able to get the door unstuck. This worked for about 2 months -then door will not open.
Help - what can i try/replace?
Thanks
Old Aug 18, 2004 | 05:55 PM
moparturd's Avatar
moparturd
Default RE: Door will not open
I would look at the door latch/lock assembly. Has anyone lubed this lately?
Old Aug 20, 2004 | 09:17 PM
gpzjack's Avatar
gpzjack
I have the same problem...so far my drivers side is fine but the passengers is stuck. I will work on it this weekend but i think most of the problem is lubrication.
Old Aug 21, 2004 | 12:18 AM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Hose that puppy down with WD-40 and let it sit for a few hours. Make sure you hit the door frame as much as you can and the hinges, if you can get to them. Do the same the lock/latch. After it opens, put a SMALL amount of graphite in the lock. A little goes a long way, and keep it off of your clothes. If you STILL have problems, check the screws/bolts holding the door to the door frame (by the hinges)
Old Aug 21, 2004 | 05:02 AM
dodgemech's Avatar
dodgemech
Is it only from the outside or both the inside and outside?
