Dodge Dart The Dodge Dart forum is the place for all Dart 2013+ Owners Discussion
Dodge Dart Limited w/GT wheels
Old Mar 26, 2015 | 10:56 PM
DrkSdeOTM's Avatar
DrkSdeOTM
Default Dodge Dart Limited w/GT wheels
Need a little help. I have a 2013 Dart Limited 1.4L. I bought a set of 18" GT wheels to put on for summer (going to use the stock 17" wheels for winter). Sticker on the door says to run 34psi front and rear w/the stock 17" wheels, but I noticed while reading on this forum that the GT recommended pressures are 38 front, 34 rear with the 18" wheels. Which should I use on my car when using the GT wheels? ANY help would be appreciated, esp if you're a Dodge technician. Thanks!
-DrkSdeOTM
Old Apr 6, 2015 | 08:34 PM
kayakman's Avatar
kayakman
Hi Drk, I would suggest putting the recommended pressure for that type of tire,, the side wall is very small. Running those 225/40R18 with less pressure might damage them. Your Limited Dart is the same as the GT. the only main difference is axle ratio, engine mapping, and suspension.
Enjoy your ride. We love our GT
cheers
Old May 19, 2015 | 12:10 AM
bogdiani's Avatar
bogdiani
Default Water Dart
