Dodge Dart The Dodge Dart forum is the place for all Dart 2013+ Owners Discussion
PROBLEM: 2015 Dart SXT- No start no crank
Old Oct 10, 2019 | 07:58 PM
mister_rtk's Avatar
mister_rtk
Default PROBLEM: 2015 Dart SXT- No start no crank
Got it to power up with a new battery and can't seem to figure out what is holding it from starting. You do heart the relays clicking when power is connected.
NEW OBD2 used and got this.
P0123- Throttle Position Sensor/Switch A Circuit High Input
P0222-Throttle Position Sensor/Switch A Circuit Low Input
P0523- Engine Oil Pressure Sensor/Switch Circuit High Voltage
P0118- Engine Coolant Temperature Circuit High Input
P0113- Intake Air Temperature Circuit High Input
U0101- Lost communication with TCM
Thinking starter replacement next but want someone with experience to tell me what they think
Old Dec 4, 2019 | 10:07 AM
Dave Lanati's Avatar
Dave Lanati
Default Electric demands
HERE'S THE VIDEO
it’s possible that your battery is not holding enough energy to provide for the electric demands that the car has.
Check the voltage of your battery, if it’s below 12.6 volts without the engine running, you probably need to replace it.
If you have a new battery, then you probably have a short circuit somewhere that is messing with the flow of electric energy.
Might be the starter. Tow it to auto zone or some other place to get it checked out.
Last edited by Dave Lanati; Dec 4, 2019 at 10:11 AM. Reason: Incomplete information
Old Jan 2, 2021 | 11:37 AM
Courtney McDonald's Avatar
Courtney McDonald
Default 13 Dart SXT
HERE'S THE VIDEO
Any resolution to this issue?
