Dodge Dart The Dodge Dart forum is the place for all Dart 2013+ Owners Discussion
2014 Dart Limited Dies and stalls..
Old Nov 10, 2019 | 05:08 PM
Murphree35's Avatar
Murphree35
Default 2014 Dart Limited Dies and stalls..
So I bought my Dart 2 months ago, and after roughly 11k miles, it started to stall out . It mainly does it when stopping or turning, then it is a pain to get to restart.. If you let it sit bout 30 min it will start up. It started it few days ago, and did it 2 times and then was good for bout 6 hrs then did it again. Since then it is more frequent.. Anyone have a direction to go with it
Old Nov 11, 2019 | 02:25 PM
Murphree35's Avatar
Murphree35
Problem solved.. The 2.4 has a oil consumption issue and when the oil level drops to low, it causes the motor to stall out..
Old Nov 11, 2019 | 03:04 PM
primem's Avatar
primem
makes sense...the multiair engine has valves that are hydraulically operated..no pushrods or conventional lifters.
that is why they use a oil pan heater instead of a coolant block heater...so the valves open on cold starts.
