Dodge Dart The Dodge Dart forum is the place for all Dart 2013+ Owners Discussion
Window issues
Old Apr 27, 2020 | 02:25 PM
Colla Kronk's Avatar
Colla Kronk
Default Window issues
Hey guys, I am new to this but I'm hoping I can get some help. My main switches for my windows on my drivers side works perfectly and will roll each window up and down without any issue. However, if you are sitting in the back seat or the front passenger seat, you cannot roll your window down using the switch on the door. If I roll them down, you can roll them up, but the switches will not roll each window down.
Old May 3, 2020 | 01:53 PM
master tech's Avatar
master tech
Site Moderator & Tech
Do you have a window lock on the master window switch?
Old May 3, 2020 | 02:03 PM
Colla Kronk
I do, but the window lock is only for the back windows. I have made sure the lock is not on. But the passenger window and both back windows will still only roll down by the master switch. They will roll up though with each switch after I roll them down with the master..
Old May 5, 2020 | 01:47 AM
master tech
I would try a known good master window switch from maybe a pick and pull. The switch just pops up with a plastic trim stick.
