Dodge Daytona The G platform cars that are to this day, fun sporty machines that car modding enthusiasts love to get their hands on, the Dodge Daytona and Chrysler Laser.
MAYDAY
Old Jul 28, 2007 | 11:21 PM
Zenguitar's Avatar
Zenguitar
Default RE: MAYDAY
Error Codes (Thanks Turbo)
After putting rocker back in, spark plugs and new coolant temp sensor
If I read it right.
on off on off on...then saw
1 (Pause) 2 (Pause) 2 (Pause) 4 (Pause) 2 (Pause) 1 (Pause) 5 (Pause) 5
So I'm thinking that means:
1-2
2-4
2-1
Old Jul 29, 2007 | 02:07 AM
shelbydaytona91's Avatar
shelbydaytona91
Default RE: MAYDAY
Might want to try pulling them again, because they will go in order. Sometimes the pauses will be different legenths but the longer lengths are the pause inbetween the two codes. Code 12 just means the battery has been plugged in recently. Here is a site that goes more indepth on how to pull the codes and what they mean http://www.allpar.com/fix/80s-codes.htmlGood luck!
Old Jul 29, 2007 | 08:23 PM
Zenguitar's Avatar
Zenguitar
Default RE: MAYDAY
That nails it....thanks
Looks like the battery was disconnected....need a new O2 sensor and TPS
How do I perform a reset?
Thanks again for the help.
Old Jul 29, 2007 | 11:12 PM
shelbydaytona91
Default RE: MAYDAY
Resetting the computer is pretty trick you have to take it to a dealer they charge about $500 for it...
Just kidding , you justunplug the negative side of the battery for about 30 seconds(altought I wouldn't be surprised if the dealership charged that)
Old Aug 5, 2007 | 07:09 AM
mech1nxh's Avatar
mech1nxh
Default RE: MAYDAY
Neat trick here on ecm reset....
dissconnect the POS cable , and connect to the NEG ....for 3 or so minutes
As electron flow goes NEG to POS.....this will discharge all of the capacitors
in the ecm (caps act like a small "battery" and hence retain the " learned " parameters)
And force the ecm to revert to the prom base functions.and "relearn" all parameters.
also your code read is....12 24 21 55
12....battery dissconnect (last 30-100 key cycles...lol ..nebulous at best)
24....t/p sensor...set code if above 4.7v or below .16v
21.... O/2 sensor no "switch" (above or below .5v for 2-12 min, again "vague" at best)
55....end of code sequence
