Dodge Daytona The G platform cars that are to this day, fun sporty machines that car modding enthusiasts love to get their hands on, the Dodge Daytona and Chrysler Laser.
sepentine belt tensioner
Old Dec 31, 2009 | 02:40 PM
Hatchnet's Avatar
Hatchnet
Default sepentine belt tensioner
im pretty sure my belt tensioner is going. as the weather changes i get a bad squealing from the sepentine belt that wont stop for a few days then goes away. im pretty sure its never been replaced even when the belts were changed. the problem i have is i cant find how to remove and install the tensioner. i have a repair manual but it only goes into adjusting the ac belt tension not replacing the tensioner. can anybody help with this?
Old Jan 2, 2010 | 06:22 PM
92dak5.24x4's Avatar
92dak5.24x4
There are 2 tensioners. One for the a/c and the other for the alternator and PS. Have to tested the belt tension? And to replace the tensioner, there's one fastener that attaches it to the engine mount plate. It shouldn't be rocket science to find that one item. Most repair manuals will assume you can find a bolt which is probably why they don't hand hold.
Old Jan 3, 2010 | 03:41 AM
Hatchnet's Avatar
Hatchnet
i actually got it figured out today. after you remove the alternator you can get to the nut that holds it in place which is on the back side of the engine in a blind hole next to the spark plug. the problem i had was the tensioner has just 1 bolt and an index stake attached to it, it looked as if it just screwed into the the side of the block. and as for the v belt adjustment on the ac its in the manual, the serpentine belt is not.
Old Jan 3, 2010 | 09:04 AM
92dak5.24x4
of course there is no adjustment proceedure on a part that is self adjusting!
