Dodge Daytona The G platform cars that are to this day, fun sporty machines that car modding enthusiasts love to get their hands on, the Dodge Daytona and Chrysler Laser.
Daytona Ignition Problem
Old Jul 2, 2005 | 01:25 AM
Aires's Avatar
Aires
Default Daytona Ignition Problem
I have an ’88 Daytona Shelby Z TII. The engine sometimes just cuts out and dies while driving down the road or just sitting idling. When the engine dies code 54 shows up (distributor sync pick-up circuit). After sitting for a few minutes the engine will start and die again at some other inconvenient time. I replaced the hall effect pick-up and checked the wiring from the hall effect pick-up to the computer. I have even wiggled the wires while the engine was running and could not get the car to die. I read the post from about a year ago, but it did not say if or what fixed the problem. Any help is appreciated. [X(]
Old Jul 8, 2005 | 04:33 PM
rockman's Avatar
rockman
Default RE: Daytona Ignition Problem
I have a 87 Shelby z. About 5 years ago I had the same problem with the engine cuting out while driving. I finally figured out that it was the distributor. When you remove the cap and the hall effects moduel you will notice that their is a metal plate held in place with 4 plastic rivets, these rivets wear out causing the plate to shift and causing a misalignment with the hall effect moduel. You can replace the plate and shaft or the distributor. I got mines from the junk yard, dealers wanted to sell the hold distributor for much $$.
