Dodge Daytona The G platform cars that are to this day, fun sporty machines that car modding enthusiasts love to get their hands on, the Dodge Daytona and Chrysler Laser.
'91 Transmission Swap
Old Jun 21, 2012 | 02:38 PM
KGBots's Avatar
KGBots
Default '91 Transmission Swap
I have a 1991 Daytona with the 6G72 V6 and the A604 4-speed automatic transmission but from what I can tell the seals inside the transmission are shot and the car is stuck in limp mode.
I'm looking at swapping in a 5-speed manual if I can afford it but I have no clue which transmission would bolt onto the 6G72 properly or what else i need besides pedal assembly, shifter and cables.
Any info would be appreciated.
Old Jul 15, 2012 | 07:00 PM
I_Ride_Neon's Avatar
I_Ride_Neon
I have honestly never swapped one before, but usually the basics are the same on all cars:
Trans
Tranny mount, maybe 2 mounts depending on car
1 axle
Computer
Shifter assembly with cables and bushing
Clutch pedal, brake pedal, hardware, clutch cable
^If its hydro you need a master, slave, reservoir, and line
ECU
Reverse light wiring with switch
Flywheel, pressure plate, clutch, bearing, and bolts
I am sure I am missing a few things, but all in all its not worth the time unless you have a donor car. Your better off fixing it to sell then buy a 5 speed car.
