Dodge Daytona The G platform cars that are to this day, fun sporty machines that car modding enthusiasts love to get their hands on, the Dodge Daytona and Chrysler Laser.
Oilchange tranny
Old Jul 11, 2012 | 09:48 AM
Heine Back's Avatar
Heine Back
Default Oilchange tranny
Daytona -93 with man tranny, Cant find the drain plug for oil-change. See filler rubberplug, but there is drainplug?
Old Jul 15, 2012 | 06:52 PM
I_Ride_Neon's Avatar
I_Ride_Neon
What motor is in it? There should be a bolt for the drain. Some trannys say Oil drain above it. Some can be found on the side of the trans, or the bottom. Let me know the motor, I can snag a picture of mine if you have the 2.2.
Old Jul 17, 2012 | 04:53 PM
dextrozol's Avatar
dextrozol
motor is 3,0
Old Jul 17, 2012 | 06:17 PM
I_Ride_Neon
Sorry it turns out they dont have a drain plug. Here is something I found on google that explains how to install a drain plug. Hope this helps.
"I stumbled across this today. I had to change the oil in a Daytona and I have seen Cliff's method-excellent if the tranny is apart but I really don't want to drop the K-member and remove the rear cover. I started to thread it in the hole at the bottom of the case and it started to cut thread-bingo, in like gold. I then made a hole using a 1/4 inch drill bit, drained out the oil, then used a 1/2 drill bit, then a die grinder to get rid of the lip and tapped it. Flushed the hole with some brake cleaner, I am not too concerned with a little bit of aluminum. Applied some thread sealer to a 1/2 pipe plug and voila, 20 mins of time and a nice drain plug installed.
Note, This may have been done before but never seen or heard of it.
Edit, you can go one size smaller on the drain plug size if you want."
Old Jul 22, 2012 | 05:02 PM
dextrozol's Avatar
dextrozol
Thanks for picture, that helps
