Dodge Daytona The G platform cars that are to this day, fun sporty machines that car modding enthusiasts love to get their hands on, the Dodge Daytona and Chrysler Laser.
86 turbo z no start issue
Old 05-21-2019, 03:00 PM
86 turbo z's Avatar
86 turbo z
86 turbo z is offline
Default 86 turbo z no start issue
looking for info on a no start issue, the car seems to have spark and fuel, the timing looks to be set right .... car will hitch the first couple revolutions but then no sign of starting at all, cannot figure this out looking for a starting point before i buy a bunch of unneeded parts
The following users liked this post:
cooler (07-06-2020)
Old 05-21-2019, 06:12 PM
Moparite's Avatar
Moparite
Moparite is offline
Might want to make sure it has spark and fuel. More info would help also, Did this just start or was the car sitting for years? Any codes?
http://www.allpar.com/fix/80s-codes.html
Old 05-22-2019, 01:34 AM
86 turbo z's Avatar
86 turbo z
yes it is getting fuel, the car was sitting for 2 years but ran when parked. but someone cut both pickups coming out of the distributor, i repaired them both but not sure if that is causing the problem.... the only code i get is 24. i ordered a new coil and distributor..... but any other ideas would greatly appreciated
Old 05-22-2019, 06:36 AM
Moparite's Avatar
Moparite
Moparite is offline
Code 24 is an issue with the TPS, May want to replace it. It maybe telling the pcm wrong info. Also try using starting fluid and see if it fires. The gas may be stale.
Old 05-23-2019, 05:51 PM
marty mopar's Avatar
marty mopar
marty mopar is offline
injectors can be plugged with old gas.....happened to me. Would run only if you put gas in the throttle body
Quick Reply: 86 turbo z no start issue
