Dodge Daytona The G platform cars that are to this day, fun sporty machines that car modding enthusiasts love to get their hands on, the Dodge Daytona and Chrysler Laser.
5 speed shifter broken - HELP
Old May 16, 2004 | 08:28 PM
stratipuck's Avatar
stratipuck
Default 5 speed shifter broken - HELP
Hi there, I have a 1990 Daytona with a 5 speed. The reverse "lift lever" broke, or the cable in the reverse. Does anyone know where to get parts and what I need to fix it? Pictures would be great, but I know Im asking for too much.. Thanks
Old May 17, 2004 | 08:56 AM
71RoadRunner's Avatar
71RoadRunner
Default RE: 5 speed shifter broken - HELP
That happened with my '88 Shelby Z. If you unscrew the shift **** you will see a white plastic tab that is now probably broke or one of the barbs/ramps has worn off or flat. I went to the junkyard and found another manual trans car and got the same peice just to have it do the same. I eventually put a hole in the white plastic part and used tie wire through it to get it functioning again. It may look ugly, but it worked and you can't see any of it with the shift **** on. If your problem isn't this part, then happy hunting.
Old May 17, 2004 | 06:27 PM
stratipuck's Avatar
stratipuck
Thanks so much, that helps very much, Ill do that !!!
Old May 18, 2004 | 10:37 AM
71RoadRunner
Not a problem.[sm=smiley20.gif]
