Dodge Daytona The G platform cars that are to this day, fun sporty machines that car modding enthusiasts love to get their hands on, the Dodge Daytona and Chrysler Laser.
wont idle cold??
Old Jan 28, 2007 | 07:09 PM
dirtmod0's Avatar
dirtmod0
Default wont idle cold??
i have a 89 daytona that doesnt idle when its below freezing out. its a non turbo 2.5 liter with throttle body injection.the engine will just shut off andwhen i start it back up it fires right up and have to hold the throttle.what i have to do is play with the throttle a bit and when the it gets warm then it starts to idle by itself. it doesnt seem like its running full rich like the engine coolant sensor is messsed up. it doesnt miss or run rough when i have it throttle up. no check engine light or anything in that nature. my guess would probably start with maybe tps sensor or iac motor?
Any advice appreciated.
Old Jan 29, 2007 | 08:24 AM
71RoadRunner's Avatar
71RoadRunner
Default RE: wont idle cold??
Throttle body injection sucks, it's often times worse than carburation and they usually have the same negative problems carburators do, but are not as easy or cheap to fix. You might be able to fix it simply by cleaning it with Gumout carb and choke cleaner, try that first since it's the cheapest and easiest.
Old Jan 29, 2007 | 11:07 AM
damageincracing's Avatar
damageincracing
Might I also suggest pulling the codes (if there are any). If cleaning the throttle body doesn't help, that may give some clues as to what may be going on.
Old Jan 30, 2007 | 02:05 AM
jblwired's Avatar
jblwired
I had this happen. In my case my iac plunger was plugged up from to much blow by over the years. Didn't make sense why it idled warm though. Although, I,ve heard of this symptom caused by other problems. I think your on the right track though. Please let us know. Good luck.
Old Jan 31, 2007 | 01:59 PM
coolcat's Avatar
coolcat
Mine did the same thing alot. I went and picked up some really good injector cleaner and started running premium gas and it doesn't do it anymore. might give it a shot.
Old Feb 1, 2007 | 08:34 AM
vicco27's Avatar
vicco27
The problem could berelated to the PCV valve or the EGR valve system also Change the PCV valve first there cheap, then try removing and cleaning the EGR valve and system. Good Luck.[sm=confused06.gif]
Paladin........Have Daytona , Will Travel ![sm=icon_cheers.gif]
Old Feb 1, 2007 | 07:19 PM
dirtmod0's Avatar
dirtmod0
Thanks for the responses, I am going to try the carb cleaner first and go from there, its been to darn cold to work outside after work. I will let you guys know what happens.
Old Feb 12, 2007 | 03:54 PM
dirtmod0's Avatar
dirtmod0
again thanks for the replys. i put in some fuel injector cleaner and did the carb spray deal andso far so good.
