Whats the biggest size tire?
I am looking to add some nice beefy tires to my truck for the winter on my stock 17 inch wheels. I know currently there is like a 265.70/17 on there or close to it? What size will give me a bit more width and height?
Get yourself 285/70/17 are almost 33" and 315/70/17 are almost 35".
You can get away with the 315's which actually measure 34.46" with some rubbing as long as you got a leveling kit. 285/70/17 will give you 32.80" and minor rubbing.
Now do you think seeing that Im using the tire for snow, that going border line big is not worth it? Would like a 275 be safer?
Also, what do you think of these tires guys? For snow in MAine.
The Wrangler DuraTrac
you cant put the 315's on the stock rims, they need 8.5" width or bigger and the stock rim is a 7" width. The 285's are as big as you should go on the stock rims, and the 275's are stock on the TRX4's so you're fine with those too.
I had 305/60/r20 on my 20" wheels with no rub.They were Goodyear SRA's....very close to rubbing,but did not.A 305/55 would prob be the best choice IMO.Although the sizes may vary with a 17" wheel,I would check to see.......
Trending Topics
I think that the 285/70/17s require a wider rim than the 7" stock. Sure you can probably mount them on the stock rim but the manufacturer does not recommend it
