Whats the biggest size tire?
Old Oct 15, 2010 | 08:15 PM
JoesBrotherRamMan's Avatar
JoesBrotherRamMan
Default Whats the biggest size tire?
I am looking to add some nice beefy tires to my truck for the winter on my stock 17 inch wheels. I know currently there is like a 265.70/17 on there or close to it? What size will give me a bit more width and height?
Old Oct 15, 2010 | 08:24 PM
WhtRam's Avatar
WhtRam
Get yourself 285/70/17 are almost 33" and 315/70/17 are almost 35".
You can get away with the 315's which actually measure 34.46" with some rubbing as long as you got a leveling kit. 285/70/17 will give you 32.80" and minor rubbing.
Old Oct 15, 2010 | 08:38 PM
JoesBrotherRamMan
Now do you think seeing that Im using the tire for snow, that going border line big is not worth it? Would like a 275 be safer?
Also, what do you think of these tires guys? For snow in MAine.
The Wrangler DuraTrac
Old Oct 22, 2010 | 02:08 PM
Zigggy's Avatar
Zigggy
I'm getting new winter tires next week- I've decided to go with 285/70/17 Blizzaks. I figure it's at least better than stock but not so big that you'll lose a ton of traction. Plus they won't rub.
Old Oct 22, 2010 | 02:17 PM
jaflowers's Avatar
jaflowers
you cant put the 315's on the stock rims, they need 8.5" width or bigger and the stock rim is a 7" width. The 285's are as big as you should go on the stock rims, and the 275's are stock on the TRX4's so you're fine with those too.
Old Oct 22, 2010 | 02:22 PM
Talon_66's Avatar
Talon_66
305/55/20 will fit the 20" rim and barely clear.
Old Oct 24, 2010 | 07:52 PM
ridem high's Avatar
ridem high
I had 305/60/r20 on my 20" wheels with no rub.They were Goodyear SRA's....very close to rubbing,but did not.A 305/55 would prob be the best choice IMO.Although the sizes may vary with a 17" wheel,I would check to see.......
Old Oct 25, 2010 | 11:27 AM
Pedro Dog's Avatar
Pedro Dog
Default Watch out for the tire salesman
I think that the 285/70/17s require a wider rim than the 7" stock. Sure you can probably mount them on the stock rim but the manufacturer does not recommend it
