recon rear light bar
got it on today & wired and it works ! i ran a four prong pig tail off the wiring harness then taped into the hot wire and reverse wire works great and leaves the plugs on the bumper open for other uses will take pic's tonight anybody got access to cab lights for the 2011 ? just a stock recon pic
hey trashman that's what i do haul trash yes it does cover the hole but there are little screws that hold it on that you can unscrew the light bar to access the winch hole never had to do it on any truck that i have had just lucky i guess
redram i guess we have similiar taste all the way around diggin the inferno red same as mine.. i had a 60'' light bar in my hand and decided against it because of the spare winch hole location. might have to go get it it looks pretty good. how hard was it to splice the pigtail into the harness.
yep tow package with 4/7 but i want to leave all that stuff alone what i was wanting to do is to splice into the 4 and hide the actual connection behind the bumper. I am lucky enough to work for waste management brand new Mack frontloader sure wish i was in NV. not OH
yep tow package with 4/7 but i want to leave all that stuff alone what i was wanting to do is to splice into the 4 and hide the actual connection behind the bumper. I am lucky enough to work for waste management brand new Mack front loader sure wish i was in NV. not OH
Trending Topics
all our auto is recycle im running stop to stop 900 plus stops a day anywhere from 8 to 15 tons a day depending on the route and area. im going to go pick the light bar up tomorrow and give it a go hope it turns out.
What's the best way to tap into the trailer wiring harness to make a quality connection that is sealed from the elements? I don't want to use the 'vampire clip' connectors. I prefer the idea of soldering things together but unless I totally cut the stock wiring I can't get heat shrink on to seal it. Other ideas?
Thanks,
Rob
Thanks,
Rob
Thanks,
Rob
Thanks,
Rob
