With 3.92 what RPM with 17" or 20" factory tires @ 65mph
For those that have the 3.92 gear with the factory 20” or 17” rims/tires I have a question. When the truck is fully warmed up and you’re traveling at an indicated 65 mph on a level road WHAT IS THE RPM OF THE TACHOMETER READING? Please list if you have the 17” or 20” rims. I need to know both. If you have 3.55’s…..please refrain from replying.
Thanks
Thanks
Originally Posted by 08DodgeTRX View Post
Its the overall tire size and rear gearing thats important not wheel size.
If you both go back and read my post I stated that I'm interested in the "factory stock wheels and tires" when making this test. I know what the factory tire size is for the 20" and 17" 4th Gen Ram.
The 20" has a diameter of 33" and the 17" has a diameter of 31.7"
the factory 265-70R17 tires are 31.6" tall and the 265-60R20 are 33" tall. With the 31.6" tires, the RPMs are, 3rd gear=2706 RPM, 1st OD=2030 RPM and 2nd OD=1813 RPM. For the 33" tires the RPMs are, 2595, 1947 and 1739 respectively.
Trending Topics
THANKS!
Find overall gear ratio- (3.92 gears is 2.6264)
OVER DRIVE GEAR x REAR GEAR = OVERALL GEAR RATIO (OGR)
FIND YOUR RPMS at ANY SPEED-
SPEED x OGR x 336 / TIRE HIGHT = RPMs
You can figure it out yourself now
