How much diff fluid
Gettin ready to change front and rear diff oil. It shows in my manual what weight to use but not how much, can anyone tell me front and rear amounts, thanks in advance.
Transfer Case
NV 243 3.4 Pints 1.6 Liters
NV 246 4.0 Pints 1.9 Liters
Axles
C205FD Front Axle 56 ounces 1.6 Liters
**9.25 Rear Axle 74 ounces 2.2 Liters
**Limited-Slip Rear Axles require the addition of 118 ml (4 oz.) MOPAR® Limited Slip Additive or equivalent
Axles
I recently did both front and rear diffs. I used redline gear oil, one plus with it is you don't have to use the additive.
Trending Topics
Another note when doing the pumpkins, when done, the levels on the '09 should be within these notes
Front Unit
Fill Level - From Bottom of Fill Hole 20 mm (3/4 in.) ± 3 mm (1/8 in.)
The rear unit
Fill Level - From Bottom of Fill Hole 3 mm (1/8 in.) ± 3 mm (1/8 in.)
Front Unit
The rear unit
