4th Gen Ram Tech2009 - 2018 Rams and the 2019 Ram Classic: This section is for TECHNICAL discussions only, that involve the 2009 - 2018 Rams and the 2019 Ram Classic. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
The other day I put my tailgate down and happened to notice that it appears that only one cable is holding the tailgate up. The other side is way, way loose. Took it to the dealer and they said it was normal?????. I have never put any kind of load on the tailgate so that's not the problem. If I sit way on the corner of the tailgate then the cable will catch and hold the tailgate. Bent tailgate??
Maybe they just didn't swag the cable ends on properly. One cable might just be a tad longer than the other cable. I just checked and mine are both tight. (no slack when down)
Can you take the two cables off and compare? Sometimes the cables can slip in the ends too if they did not swag them tight enough.
I had the same issue took the cables off and one was longer then the other went to the dealer and they replaced with a new set of cables. I have an 09.
Same issue but Ihave a ram on one side to slow the tailgate down so that might be my issue. It closes and opens nicely, with 2 fingers and fit is perfect.
