Dodge Towing Capacity
This link is great. Tells you what your towing capacities are for your truck. Just click and go. Check it out.
http://www.dodge.com/bodybuilder/year.pdf
Note: For those of you with a '09. I would use the '10 because they bumped the towing up and made zero changes to the truck.
Also shows all kinds of different info.
google 'Ram body builder' and you'll see the link there as well. the document is a web-based pdf full of active hyperlinks, so it takes a while to load (and can act a little wonky once loaded). it's extremely useful though and has many specs on your truck that you can't typically find.
